Tester builds 2.0.0 (1.2.0)
PreviousPage 2 of 4Next
Please, can we have an updated of the tester build ?
Many things have been corrected since the last December version.
Thanks
Fizik_S has reacted to this post.
Fizik_S
I still need to solve a few things.
Probably it will not be version 1.2.0 but 2.0.0
Fizik_S and KerimF have reacted to this post.
Fizik_SKerimF
Version 1.2.0 was cancelled in favour of 2.0.0 and has some important changes that makes it incompatible with older versions.
Version 2 uses a new extension .sim2 for circuit files, so older circuits are not overwritten.
You can download in tester section: https://simulide.com/p/testers/
Most relevant changes:
- New extension .sim2
- Component library installer/updater (Left Panel).
- Wire current animation (Settings->Circuit->Animate Currents).
- Logic Components:
        More configurable.
        Invert Pins individually (Right-click).
        New Configurable Binary Counter.
        New Magnitude Comparator.
        Shift Register: resizable, bidirectional, parallel inputs.
        Full Adder: resizable.
- Experimental ESP32:
GPIO and I2C should be working.
Very unstable, it can freeze the application, only for basic testing.
There is a test circuit included in the downloads.
If you have any questions, please let me know.
Fizik_S and daVinci have reacted to this post.
Fizik_SdaVinci
Thank you for the effort.
I found that the link to the windows version is still 1.2.0 instead of 2.0.0
Quote from desmondchan71 on August 8, 2025, 6:02 pm
Thank you, it should work now.
I noticed a bug in Arduino Uno, if you select the package 'Logic Symbol' it squeeze de board image instead of the traditional rectangle.
arduino_bug
Hi. Thanks for reporting.
I will have a look.
I can't believe the ESP32's EN pin can withstand a 5kV voltage; that's completely against common sense.
And ? What do you expect that will happen in the simulation ?
 I hope the esp32 cannot operate without power, the pin voltage tolerance is consistent with the datasheet, and exceeding the withstand voltage should cause damage. Similarly, a warning should be issued when the supply voltage is too low, and the simulator should explicitly state that the mcu is not working properly. The simulation should try to follow natural science as much as possible.
