Forum breadcrumbs - You are here:ForumDevelopment: TestersSimulide 2.0.0
Simulide 2.0.0
PreviousPage 2 of 3Next
Compiling error:
/home/feri/Qt_Projects/SimulIDE-dev-master/src/microsim/cores/qemu/esp32/esp32usart.h:27: error: ‘void Esp32Usart::connected(bool)’ marked ‘override’, but does not override
In file included from ../src/microsim/cores/qemu/esp32/esp32usart.cpp:8:
../src/microsim/cores/qemu/esp32/esp32usart.h:27:14: error: ‘void Esp32Usart::connected(bool)’ marked ‘override’, but does not override
27 | void connected( bool c ) override;
/home/feri/Qt_Projects/SimulIDE-dev-master/src/microsim/cores/qemu/esp32/esp32usart.cpp:77: error: ‘QEMU_USART_SENT’ was not declared in this scope; did you mean ‘QEMU_USART_RECEIVE’?
../src/microsim/cores/qemu/esp32/esp32usart.cpp: In member function ‘virtual void Esp32Usart::frameSent(uint8_t)’:
../src/microsim/cores/qemu/esp32/esp32usart.cpp:77:23: error: ‘QEMU_USART_SENT’ was not declared in this scope; did you mean ‘QEMU_USART_RECEIVE’?
77 | m_arena->mask8 = QEMU_USART_SENT;
| QEMU_USART_RECEIVE
:-1: error: [Makefile:12140: build/objects/esp32usart.o] Error 1
Now it compiles, but the side menu for adding Arduino, AVR, Pic, etc. doesn't work.
Regards
Quote from feri on December 16, 2025, 7:10 pm
Regards
How doesn't work? What happens?
When I start SimulIDE the items Arduino - Avr - Etc.. do not appear in the menu, by right-clicking and selecting "manage component" I put the check mark on Arduino - Avr and also the other items under "Micro" the items appear in the menu but the Avr - Pic - Msc65 - Shields menus do not expand and the others I51 - Z80 - STM32 - Espressif do not drag into the diagram the pointer becomes a hand with a crossed out circle.
Have you installed those components?
Now you can use the second tab to install and update components:
I copied the "Converted_from_1.1.0" directory to the simulide directory and set it as the "User data folder" but I can't install the components.
Don't use those components. just install what you want from the second tab.
The installer doesn't work, I click the button and nothing happens.
Quote from feri on December 17, 2025, 9:07 pm
Not sure which button are you clicking.
Install button is the one at the right side.
I found that the first time it is empty (I just fixed it) but anyway it works:
It works now, but only Arduino UNO can be inserted. For example, Arduino MEGA gives the following error:
"Chip::getPackages" Error: Cannot read file "/home/feri/.local/share/simulide/components/Arduino/arduino/Uno/Mega/Mega.sim1" "No such file or directory" "SubCircuit::loadSubCircuit" Error: Cannot read file "/home/feri/.local/share/simulide/components/Arduino/arduino/Uno/Mega/Mega.sim1" "No such file or directory" SubCircuit::construct: No Packages found for "Mega".
Regards
