Tester builds 2.0.0 (1.2.0)
Page 1 of 4Next
First Release Candidate for new version 1.2.0 available for download:
Some new features in this version:
Logic Components:
- New Component: Magnitude Comparator.
- Full Adder: size configurable.
- Shift Register new properties:
    Parallel input.
    Bidirectional.
    Size.
Editor/Debugger:
- Multi-file debugging.
- Scripts highlighting and error lines.
- Some completion capabilities, specially for Scripted and Arduino:
Fizik_S, KerimF and yanx123 have reacted to this post.
Fizik_SKerimFyanx123
Here are some templates for people that want to create scripts using communication modules (SPI, TWI, UART, TCP):
script_templates.zip
KerimF has reacted to this post.
KerimF
When creating a new subcircuit, I found errors.
1. The new subcircuit appears in the list of program components at the end of the specified category. For example, I created a 74XX000 subcircuit. In the file "ic74.xml " I placed the description of the subcircuit first in the selected category "IC 74/7400-7499". After running the simulator, this subcircuit is the last in the list of subcircuits.
2. Only the "Main" tab is located in the properties of the subcircuit. The "Electric" and "Timing" tabs are missing.
3. In the "Package" list, instead of the lines "1 - Logic symbol" and "2 -Dip", there are the lines "Package-xx".
The created subcircuit works correctly.
Error #2 is solved simply: when creating a subcircuit package, you need to specify "Logic" in the properties for "Type". When creating the package, I left the default value for "Type", i.e. "None"
I discovered an interesting feature of the new subcircuit format: if you open the subcircuit file and resave it, you can delete the "*.package" package files. I will do this in my copy of the program and test for the correctness of the work of the resaved subcircuits. If there are no errors in the program, you can delete more than 600 files from the distribution! This will free up more than 1 megabyte of memory. The attached archive contains the created subcircuit 74XX000.
KerimF
Quote from Fizik_S on December 5, 2024, 9:46 pm
I found a solution to error #3. It is necessary to correct 2 values of the "label" tag in the lines describing the subcircuit packages in the *.sim1 subcircuit file. In the source files, when creating a subcircuit or when resaving a subcircuit file, "Package -xxx" is written in the "label" tag. You need to write label="1 - Logic Symbol" and label="2 - Dip" for _LS and DIP packages.
Thanks for reporting.
About 3.
Package names in the list are what you use in the circuit.
Also you can add as many packages as you want, for example:
Fizik_S has reacted to this post.
Fizik_S
Hi guys. Happy 2025 for everyone!
There are new tester builds for 1.2.0  available for download:
KerimF and NeoDarwin have reacted to this post.
KerimFNeoDarwin
Happy New Year!
It seems that there is a bug with this version 1.2.0 1231 with scripted components containing a "custom graphic element".
When a .sim1 schema contains a "scripted custom graphic element", some user interface buttons (load, save, save as, start/stop simulation) are frozen. Depending on the simulation files, the "start/stop simulation" button may be unlocked, but the simulation does not work all the time. In this case, the simulation may work (with the load, save ... buttons still blocked), or the program may freeze and then crash.
Schemas with scripted graphical components that worked before with the RC1 version do not work anymore with this version 1231.
Quote from LWT98709 on January 2, 2025, 7:10 am
Happy New Year!
Thank you, I'm already working in this and it is more or less solved.
Indeed there are at least 2 issues, 1- crash and 2- frozen buttons.
The frozen buttons issue is quite weird (and is pre-RC1) I know how to fix it but still not sure why it happens, and I probably need to find a better solution.
When creating a new subcircuit, the "bus" mode is not saved for the pin. If you manually enter the pin mode "type=bus;" in the subcircuit description file, the subcircuit works correctly.
Quote from Fizik_S on June 21, 2025, 10:11 am
Thanks, this issue is already solved.
Fizik_S
Page 1 of 4Next
