Sinewave Current Generator?
Quote from KerimF on April 10, 2025, 5:25 pmHi
I wonder what the
simplestpractical way to implement a sinewave current generator in simulIDE could be.Thank you.
Kerim
Hi
I wonder what the simplest practical way to implement a sinewave current generator in simulIDE could be.
Kerim
Quote from KerimF on April 10, 2025, 8:14 pmNow, I use the available voltage wave generator (set to Vpk) in series with a resistor (Rs) whose value is much higher than of the load.
For example, if the load is 50R and Ipk = 50 mA, Rs could be set to 10,000,000 Ohm which gives Vpk=500,000 V.
Quote from KerimF on April 11, 2025, 4:22 pmQuote from arcachofo on April 11, 2025, 8:30 amHi.
Maybe you can use a voltage controlled current source?
It was my first thought too. But I am not sure why it didn't work when I added it to a schematic of a project.
I will try to test it again on a new schematic and see what I will get.
