SimulIDE 1.1.0 Program Counter crash, 8051
PreviousPage 2 of 2
#11 · October 13, 2024, 10:48 am
Quote from ivo on October 13, 2024, 10:48 amHmmm, you are right. In a bare file without any of the 'unused' code, it now works again. Somehow my other code which is never executed, stops it.
I put, the interrupt routine back in.
unsigned short duty_on = 0; unsigned short duty_off = 0; unsigned int timer1_of = 0; unsigned long count_result = 0; volatile char counting = 0; void timer0_isr(void) __interrupt(TF0_VECTOR) { // Stop timers TR0 = 0; TR1 = 0; // Calculate result of timer 1 count_result = ((unsigned long)TL1) + (((unsigned long)TH1) << 8); count_result += ((unsigned long)timer1_of) * ((unsigned long)65536); counting = 0; }Even though theoretically it would never run? Somehow it stops everything running.
Appears having the line
count_result = ((unsigned long)TL1) + (((unsigned long)TH1) << 8);somehow crashes it
// Stop timers
TR0 = 0; TR1 = 0;
counting = 0;
Appears having the line count_result = ((unsigned long)TL1) + (((unsigned long)TH1) << 8);
somehow crashes it
PreviousPage 2 of 2
