Separate contacts and coils of relays
Quote from RandomGuest on June 12, 2026, 10:30 amWith my job it always requires to read large relay schemes where coils and contacts of relays are displayed separated. Like in one corner of drawing there is a coil "KL1" and in another part of scheme is a contact "KL1", if the coil is powered the contact is triggered. Like it has been realized in "EKTS" program. Typically relay simulators like SimulIDE display coils and contacts together, as a parts of the same unit visually. Do you consider an option to display them separately in the future plans? I know it'd require the rule of same naming within the scheme and probably contradicts the common principle of realistic simulators, but it is still wished...
