Scripted components | Implementation of arrays
Quote from arcachofo on May 26, 2025, 7:58 amQuote from dmilardo on May 25, 2025, 3:35 pmI've copied your files and the circuit, but Simulide still crashes when I turn off the voltage at ENABLE, which allows the values to be read from the array. I'll discuss it with my professor again. Perhaps my PC is also causing the problem.
Which OS are you using?
Also, maybe you can try the last tester build: https://simulide.com/p/testers/
Quote from dmilardo on June 2, 2025, 11:52 pmI apologize for not responding sooner.
My current OS is WIN 10 Home. I will test this version, thanks.
Quote from arcachofo on June 3, 2025, 3:00 pmOk thanks.
I assume it is Windows 64 bits...
I will try in Windows as well and see if it is something specific for this OS.
Ok thanks.
