Forum breadcrumbs - You are here:ForumGeneral: HelpScripted component twi master
setMode works but calling sendByte crashes the application.
I need sample code for this sequence:
start
sending address (r/w = 0)
sending one byte
restart
sending address (r/w = 1)
reading 3 bytes
seanding NACK after last byte
stop
I also need to know how to check if slave sent NACK?
Hi there.
TWI Master mode for Scripts is not yet implemented, but I think is not too much work.
I will have a look.
nemka has reacted to this post.
nemka
It explains a lot. 🙂
Thank you for your work.
It's not urgent, I can write a twi master stack in script.
