pic 16F887 support? [edited]
Quote from yontouryuu on July 8, 2024, 8:55 amHi, i'm kinda new to embedded development
I started learning pic using
p16F887ap16f877a and was looking for a good simulation program, that's why i'm hereEverything is neat and well thought so i want to keep using it
It seems to be
p16F887p16f877 is supported butp16F887ap16f877a isn'tI want to add support for
p16F887ap16f877a, but i don't know where to begin, if you would be so kind to show me some tutorials and such to help me, i would be gratefulThanks for reading until end
Edit: I somehow managed to confuse the mcu model, correct ones are green colored, sorry for mistake
I started learning pic using p16F887a p16f877a and was looking for a good simulation program, that's why i'm here
It seems to be p16F887 p16f877 is supported but p16F887a p16f877a isn't
I want to add support for p16F887a p16f877a, but i don't know where to begin, if you would be so kind to show me some tutorials and such to help me, i would be grateful
Quote from arcachofo on July 8, 2024, 9:02 amHi.
I think p16F887 and p16F887a are mostly the same.
Do you know about any significant difference?.
Quote from yontouryuu on July 8, 2024, 10:45 amI looked it up, they essentially the same, although there are some differences.
I found a device migration document online, may be it'll help us: https://ww1.microchip.com/downloads/en/DeviceDoc/39591a.pdf
Quote from arcachofo on July 8, 2024, 5:54 pmWell.. that document is for 87X, not 88X, but also in this case you can use 87X models in simulide as 87Xa.
I think there is no problem in using p16F887 model in simulide asp16F887a.
Quote from yontouryuu on July 10, 2024, 9:01 pmSorry for late response
Yes, it seems that for most part they're interchangeable, so i'll use it as is.
But still, it would be nice to fully add p16F887a as a seperate component as well
And, thanks to they being almost identical, it must be easy.
I would like to contribute and this is the most low hanging fruit i could possible take 😀
Is there a tutorial or any documentation for adding new microcontrollers?
