Maybe bug in AVR USI (Attiny85)
Quote from Coethium on August 25, 2024, 10:04 pmHi again 😉
Just a little new modification in avrusi.cpp :
void AvrUsi::callBack() // Called at Timer0 Compare Match { shiftData(); stepCounter(); setOutput(); }shitfData() must be called before stepCounter() call.
When sending data, that's not important, but when receiving data the buffer (USIBR) has to be updated after reading Pin data.
Hi again 😉
shiftData();
stepCounter();
setOutput();
Quote from arcachofo on August 26, 2024, 9:57 amThank you.
I will have a look, there are other places where shiftData() and stepCounter() are called.
Not sure why it is in this order, but I kind of remember that it was a reason, at least for some cases.
Quote from Coethium on August 26, 2024, 10:33 amI guess this is specific to the Timer Compare Match, because all actions are taken (sequentially) at the same time. Others modes of operations separate stepCounter() and I/O on different edges of the clock.
