Is there a way to see all the library that exists inside simulide?
I have wondered this because I am choosing between simulide and wokwi. I love their ui but I prefer desktop application better than website but I still need to check if there are enough libraries so I can work with. Thank you so much for answering my question!
The components available are those you see in the list.
If you need to simulate ESP32 or some other 32 bit CPU, then Wokwi is a better option.
If you need to simulate actual electronic circuits then Simulide could be your option.
KerimF has reacted to this post.
KerimF
But there is no libraries component on the list? I need the lists of library name like Stepper.h, Adafruit_GFX.h, pitch.h. Can you share images?
For PCs, the default Arduino libraries are located in the Arduino IDE directory at: Arduino/libraries. User libraries are installed by default at: Documents/Arduino/Libreries.
Quote from Tim on November 19, 2024, 12:55 pm
Simulide uses Arduino IDE installed in your system.
You can use any library you want, you just need to install the library in your Arduino IDE.
oh so i need to install arduino ide? thats good tho. One last question, can i do serial communication so i can work with opencv in python in simul ide? If yes is there documents for me?
Yes, you can do serial communication using a "Serial Port" component.
Have a look here (click in "Serial Port": https://simulide.com/p/component-list/#peripherals
Thx u so much!
