Help with Ubuntu and Arduino simulation
Quote from MA108 on February 2, 2025, 5:21 pmHi Alexey
I’m not sure that I can help you as I have no experience with macbooks. However the problem you have is similar to mine. You could try downloading the Linux 64bit zip file and extraction it into a folder in you home directory. Select this folder as the tool path. I think this may work as it should contain the tools SimulIDE is looking for.
Hi Alexey
Quote from Alexey on February 2, 2025, 5:27 pmHi MA108!
Thank you for your reply and willingness to help, but Software compiled for Linux will not work on macOS.
Hi MA108!
Quote from arcachofo on February 2, 2025, 6:25 pmHi.
I think in MacOs you need to use a folder which is "inside" the app, something like this:
/path/to/Arduino IDE.app/Contents/
Quote from Alexey on February 2, 2025, 6:39 pmHi arcachoto!
I cannot select this file (Arduino IDE) because it is not active in the selection window.
Hi arcachoto!
Quote from MA108 on February 2, 2025, 6:46 pmHi Alexey
I am not suggesting that you should run the Linux program only to make the package available to SimulIDE so that it can access the tools that it requires. Sorry if that was not clear but I think that it is worth a try.
Hi Alexey
Quote from Alexey on February 2, 2025, 6:49 pmThank you very much!
It's working! But the solution to the problem is not entirely obvious))
