Compile and upload for 2 arduinos
Quote from OscarES on January 7, 2025, 3:48 pmHello friends, I am very grateful to the developer and the SimulIDE community. I have tried unsuccessfully to compile for two Arduinos with different code on the same circuit, for only one it has been fantastic, could you provide me with a link that guides me? I use Windows 11 and SimulIDE 1.1.0 latest stable version from 12/23/2024
I clarify that I have been able to do it by separately loading each HEX file generated in Arduino IDE, however I would like to do it directly from SimulIDE.
Thank you very much
Thank you very much
Quote from arcachofo on January 7, 2025, 4:31 pmHi.
When there are more than one MCU in the circuit you need to choose which one will be "linked" to the Editor:
https://simulide.com/p/compiler/#compilingIf the MCU is inside a board, like Arduino, then you can access it from Arduino context menu:
Quote from OscarES on January 7, 2025, 5:42 pmArcachofo, thank you very much for the link, I will do as you indicate. If I have two Arduinos in the simulator window, can I alternate them as the main controller? in order to program them one at a time from the editor window. I have noticed that the folder containing the .sim1 file only accepts one .ino file, if there are 2 or more it does not compile. Is this correct?
Quote from arcachofo on January 7, 2025, 6:09 pmYes, you can alternate, every time you want to change the controller to upload yo choose which one.
About sketches, you should put each sketch in a folder with the same name as the sketch.
This is not related to Simulide, it is how Arduino works.
