ATmega128 printf() not working in SimulIDE 1.1.0-SR2
Quote from joa on October 13, 2026, 2:11 pmHello,
I found an issue with
printf()when simulating the ATmega128 in SimulIDE.Environment:
SimulIDE: 1.1.0-SR2
OS: Windows 11
Compiler: AVR-GCC 5.4.0 (AVR 8-bit GNU Toolchain 3.6.2, Microchip Studio 7)
MCU: ATmega128, 16 MHz
UART0: 9600 baud
Problem:
Direct UART output and
puts()work correctly, butprintf()produces no output. The same functionality works correctly with the ATmega328P in SimulIDE.I also tested the
sprintf()example from this earlier report:https://simulide.com/p/forum/topic/avr-atmega128-sprintf-sscanf-not-working/
The following statement still does not work in SimulIDE 1.1.0-SR2:
sprintf(buffer, "\r\nTest %d", 10);These issues may be related.
I've attached
print_ex.zip, which contains two test examples:
ATmega128 (issue reproduced):
printf_ex.candprintf_ex.sim1ATmega328P (working reference):
printf_ex_atmega328p.candprintf_ex_atmega328p.sim1The two C source files are identical. The ZIP also includes compiled HEX/ELF files for both MCUs.
Could you please investigate this issue?
Thank you!
I found an issue with printf() when simulating the ATmega128 in SimulIDE.
Environment:
SimulIDE: 1.1.0-SR2
OS: Windows 11
UART0: 9600 baud
Problem:
Direct UART output and puts() work correctly, but printf() produces no output. The same functionality works correctly with the ATmega328P in SimulIDE.
I also tested the sprintf() example from this earlier report:
I've attached print_ex.zip, which contains two test examples:
printf_ex.candprintf_ex.sim1 -
Thank you!
Uploaded files:Quote from arcachofo on October 15, 2026, 10:15 amHi. thanks for reporting (again).
Finally I could find the problem.
As a workaround you can fix it like this:
Edit simulide/resources/data/AVR/mega128.mcu and set prog="65535" at line 3.
Quote from joa on October 16, 2026, 2:33 amHi arcachofo,
Thank you very much for investigating this issue and finding the cause!I changed `prog` to `65535` in `mega128.mcu` as you suggested, and confirmed that `printf()` now works correctly.
I also tested the examples from the earlier `sprintf()`/`sscanf()` report, and confirmed that those issues are resolved as well.
I really appreciate your time and effort in tracking down the problem.
Thanks again for your great work on SimulIDE!
Hi arcachofo,
