Arduino Pro Mini - 328p - Optiboot hex not working
Quote from PSOR on November 21, 2024, 2:29 pm
Quote from arcachofo on November 21, 2024, 2:16 pmCool!
Glad you got it working despite the difficulties.
I'm glad there is progress.
Now I need to insert the ADS1115 i2c 4ch ADC 16Bit module, I see that it is not on the list, is there any option to create
Quote from arcachofo on November 27, 2024, 11:40 amHi.
I uploaded some templates for script components:
https://simulide.com/p/forum/topic/tester-builds-1-2-0/#postid-1601There is one for TWI that can be used to create the ADS1115 i2c 4ch ADC 16Bit module.
If you try it and have any questions just let me know.Note that version 1.2.0 is needed:
Quote from PSOR on March 12, 2025, 2:38 pmHi,
A strange thing ... Not working anymore hex files merged with bootloader optiboot at all 🙁
I don't know what's going on. Even on older versions of simulide... help ?SimulIDE 1.2.0-RC1-1231
Optiboot Hex's does not start correctly, does not initiate the OLED display at all.
in the zip archive are all files i try to start.
Uploaded files:Quote from PSOR on March 21, 2025, 7:02 amHi.
The problem is partly solved, communication works after RS232_Serial, I needed the most.
The problem is probably related to the registraters for the Optiboot bootloader, the Hex file itself works, you do not need to stick it with Optiboot Hex. I don't know a reset vector?
Unfortunately, I don't have a source code to check it.
The program was in a loop probably related to I2C or OLED initialization.
I changed 2 bytes in the code where he looped, moved further and communication appeared after the RS232 series.
So much at the moment I am enough to work on the application for this code with the MIT app Inventor.
Regards
Piotr
Regards
Piotr
