Arduino in subcircuit dosn't load hex file
Quote from lastactionhero9000 on February 26, 2025, 4:41 pmHello. I've created a lab setup to study a RAM chip. For this purpose, I've created two subcircuits - Counter and RAM. The Counter works fine, but the RAM subcircuit acts weird. This subcircuit contains an Arduino Uno and SSD1306 display. When I launch the simulation inside the subcircuit, the display works. But when I use this subcircuit in another project, everything except the display works. I put my subcircuits inside the Shield folder and added entries to the shields.xml file:
<item name="Counter" info="Counter" /> <item name="ram" info="ram" />I am using SimulIDE version 1.1.0-SR1.
In the archive, I will include the RAM_lab circuit (which uses subcircuits) and the folder with the RAM subcircuit.
What settings can I change to make the Arduino in the subcircuit load the hex file?
Display is working at cubcircuit:
and not working at main circuit.
Quote from arcachofo on February 26, 2025, 6:40 pmHi.
To do what you want, you should use an Atmega328 instead or the Arduino.
Then set that Atmega328 as "exposed" as explained here:
https://simulide.com/p/subcircuits/#exposed-componentsAfter that your board will work as an Arduino: right-click->mega328->Load_firmware
Quote from lastactionhero9000 on February 26, 2025, 6:52 pmThanks for the advice. I will try your sollution and return with results.
Quote from lastactionhero9000 on February 26, 2025, 7:10 pmQuote from arcachofo on February 26, 2025, 6:40 pmHi.
Everything works now. Once more thank you for the help and awesome simulator.
So, there is no way to load hex-file automaticaly after subcircuit is added to the main circuit?
Quote from arcachofo on February 28, 2025, 7:52 amGlad to know you got it working.
Yes, just put the hex file in the subcircuit folder, and you load it from the subcicuit, and save the subcircuit.
In this case you don't need the "exposed component" stuff.
