About Circuit Simulation with Oscilloscope
Quote from hyblid on May 6, 2026, 3:30 pmHi,
I am learning electronic circuit base on book "Complete Electronics SELF-TEACHING GUIDE"
each component internal characters are can be different but
I got some outputs are not expected, so I am trying to report this
- Opamp (Page 375 )
expect output as below screenshot
a. output did not display wave form
b. "Volt Div" reacted same as "Volt Position" ( change Volt Div, wave moving up or down on Y-Axis)
2. Bridge Rectifier (Page 468)
everything is okay but right side of resistor's voltage is 0V (I used probe suddenly display output so I saved and open again I could not reproduce output wave)
this is expected output
I uploaded 2 files for Opamp and Bridge rectifier.
Being able to use such a good tool is a great help to me.
Thank you for your hard work.
- Opamp (Page 375 )
Quote from arcachofo on May 6, 2026, 5:56 pmHi.
About OpAmp:
Seems that polarity is not 100% correct:
- About Bridge:
You can use a ground to force 0 V on one side of the bridge:
About OpAmp:
- About Bridge:
Quote from hyblid on May 6, 2026, 11:58 pmThank you so much... it was my mistake. Next time before I post, I will take more time to check.
Now I can go to the next chapter😂
