A patch for changing from Qt5 to Qt6
Quote from stefanorsa on January 14, 2026, 8:16 pmIt worked fine for Qt 6.4.0
Thanks 🙂
So, I will use that version.
But, for Qt 6.9.0
It did not find
#include "moc_window.cpp"
and the end of mainwindow.cpp
chatgpt wanted me to remove that row, and all other #include "moc_*.cpp", at the end of files.After that I got:
I got 20:49:17: Starting /.../SimulIDE-dev/build_XX/executables/SimulIDE_2.0.0-/simulide...
Warning: QLayout: Attempting to add QLayout "" to MainWindow "", which already has a layout (:0, )
Installer::Installer "AVR" "2507102250"
Installer::Installer "Analog" "2507102250"
Installer::Installer "Arduino" "2507102250"
Fatal: ASSERT failure in : "QObject::connect: Unique connection requires the slot to be a pointer to a member function of a QObject subclass.", file /.../Qt/6.9.0/gcc_64/include/QtCore/qobject.h, line 265 (/.../Qt/6.9.0/gcc_64/include/QtCore/qobject.h:265, )
20:49:18: The command "/.../SimulIDE-dev/build_XX/executables/SimulIDE_2.0.0-/simulide" terminated abnormally.
Appendix: Some of the conversation with chatgpt
This is a classic Qt upgrade / build-system mismatch issue, and it’s not a real source-code error.
Your intuition (finding the file underbuild/.../moc/) is exactly right.What is actually happening
mocis running correctlyIt generates the file here (as it should):
build_XX/build/moc/moc_window.cpp
But your source file is explicitly trying to include it:
#include "moc_window.cpp" // ← this line is the problem
Since
mainwindow.cpplives in:project_root/src/mainwindow.cpp
the compiler looks for:
project_root/src/moc_window.cpp
which does not exist → error.
Why this happens now (Qt 6 + Creator)
In modern Qt (Qt 6):
mocfiles are:
generated automatically
compiled automatically
NOT meant to be manually included
Qt Creator / qmake / CMake handle this via AUTOMOC
Manually including
moc_*.cppis:
❌ unnecessary
❌ fragile
❌ breaks when build directories change
✅ The correct fix (99% of cases)
Remove the manual include
Open
mainwindow.cppand delete the last line:
Thanks 🙂
But, for Qt 6.9.0
It did not find
After that I got:
Your intuition (finding the file under build/.../moc/) is exactly right.
mocis running correctly -
Since mainwindow.cpp lives in:
mocfiles are:-
Manually including moc_*.cpp is:
❌ unnecessary
❌ fragile
Open mainwindow.cpp and delete the last line:
