A patch for changing from Qt5 to Qt6
Page 1 of 2Next
Hi all
I have made a patch that updates from Qt5 to Qt6. It is here https://github.com/charonplutospace/SimulIDE-dev/tree/qt5-to-qt6
It is working fine and it would be nice to go from Qt5 to Qt6 as Qt5 begins to get old.
Thank you, I will have a look.
I take a look at work as it can be a fix for https://github.com/eeTools/SimulIDE-dev/issues/84
Looking at provided branch:
* 0d2a01b8 (charonplutospace/qt5-to-qt6) Qt5 to Qt6
* e94eaa9c Change from Qt5 to Qt6
*   ac281041 Update Qt5 to Qt6
| | *   681dbdc8 (HEAD -> qt5-to-qt6, origin/master, origin/HEAD, arcachofo/master, arcachofo/HEAD, albfan/master, albfan/HEAD, master) Merge pull request #83 from albfan/external-actions
| | * | 63913b82 Merge pull request #82 from albfan/last-project-dir
| | | * 2f561b13 (albfan/external-actions, external-actions) External actions
| | * e69103d2 (albfan/last-project-dir, last-project-dir) Add Last Project bookmark
| * 38c1259b QemuDevice: Update files to "cpu only" implementation.
| * 7259cc6b Fix PIC CCP unit.
| *   248b92fb Merge pull request #80 from albfan/linked-switch
| * \   4004490e Merge pull request #79 from albfan/i18n-es
| | * | 8b7dcff0 Fix es translation for Link
| | * | d78ca09b Fix es translation for show
| | * 95a0362f Implement linked value for switches
| *   47194c4f Merge pull request #76 from iammmmmmm/master
| | * 8720a39c Support for Simplified Chinese
| * 90555a20 ComponentList: fix compFolder;
| * 3d4f345d InstallItem: fix install button.
| * a8dcb47a Refactor Component shortcuts.
| * 89126010 Fix Create Comonent by shortcut position.
| * 1b913694 AvrWdt: fix WDP bits not saved.
| * 5d324b50 Update QemuDevice files to last changes.
* | ee432902 Rebase to latest master
* 007ed782 (charonplutospace/master, charonplutospace/HEAD) Rotary Encoder: make Mouse press transparent out of knob.
Relevant commits are:
and don't seem to be relevant here, just partial work and merges with upstream master.
My sugggestion to get this merged:
Open an issue on github
Open a PR
rebase all work:
From your branch qt5-to-qt6
git reset 681dbdc8
Mostly do it
Avoid if possible to change style and whitespace, or do in a separate commit
Just if helps I open https://github.com/eeTools/SimulIDE-dev/pull/90 with all those steps, while still crediting you as author Stefan
Don't worry, I'm already working in this.
Patch partially applied at this commit (and the previous one)
@stefanorsa thanks for the contribution, I added you as co-author of the commit.
This is the first time I commit/add something to a project on GitHub and also the first time I contribute to SimuIDE.
Questions.
1) Will my update from Qt5 to Qt6 be merged into master?
2) Do I need to make a merge request?
3) Do I need to do something else?
I just wanted to test developing SimuIDE, and I had Qt6 installed, so I thought it should just be a few updates. But it became very many.
Don't worry, you don't need to do anything else.
I just used your commits, removed some changes that are not related to the migration and made a new commit.
I didn't merged your commits, so I added you as co-author of this new commit:
https://github.com/eeTools/SimulIDE-dev/commit/52c9e1c9e764c1450ffb33461704ee74cb530c71
Have a look at your profile in Github and you will see it.
Hi @arcachofo
When I checkout the latest master, I got the errors shown in simulIDE-1.png  It does not find QStringRef
Is I ask chat-gpt:
Yes — QStringRef is no longer part of Qt 6’s core API.
In Qt5 it lived in QtCore and you could use it to hold a non-owning substring reference, but in Qt6 it was removed from QtCore as part of the modernization of the string API.
What happened to QStringRef in Qt6?
  • Removed from QtCore: QStringRef is not available by default in Qt6 anymore.
Qt5Compat module: For compatibility with existing Qt5 code, it was moved into the Qt5Compat module. You can still use it if you link against that module (e.g., Qt6::Core5Compat).
Recommended replacement: The preferred modern replacement is QStringView, which offers similar functionality (a non-owning view into a string) and is part of Qt6.
I got a lot of error and I fixed them one by one. This is why patch is so large. My patch works fine with the above versions.
There is no QStringRef in proputils.h: https://github.com/eeTools/SimulIDE-dev/blob/master/src/gui/properties/proputils.h
Maybe there is some issue in your local repo?
I will check out a clean version tomorrow and check again.
Page 1 of 2Next
