338__ELECTRONIC RHEOSTAT
Quote from Defran on December 17, 2023, 9:25 am
338_ELECTRONIC RHEOSTAT (Simulide R2116 or higher.)
A RHEOSTAT is an alternating current voltage regulator with electro-mechanical components (Cursors, Windings, etc.). Here the aim is to obtain a rheostat with electronic components to optimize space and handling, simulating it with Simulide.
The application circuit is composed of three parts in series: 1) 220 ACV power input, 2) lamp as electrical load and 3) a diode bridge in whose POSITIVE and NEGATIVE outputs the load regulation will be applied by the BUZ41 power MOS. The gate of this MOS is controlled by a potentiometer that will act as a rheostat regulator. In between there is a switch that connects or cuts off the power to the external load (lamp). The regulation voltage itself is obtained from the output of the diode bridge, rectified, filtered and stabilized by a zener, without the need for any additional DC power supply.
Use: close the "ON/OFF" switch, then act on the control potentiometer so that the lamp will vary its luminosity.
