337__MOS IN SWITCHING MODE
Quote from Defran on December 14, 2023, 2:07 pm
337_MOS IN SWITCHING MODE (Simulide R2116 or higher.)
The use and polarization of the four MOS cases of ENHANCEMENT and DEPLECTION in switching, N channel and P channel are shown here. The diagrams are sufficiently explanatory. Each MOS is controlled by a push button and the operating status is displayed on an LED.
a).- ENHANCEMENT, N Channel. At rest the MOS does not conduct. When you press the button, the GATE is polarized with 5V, the MOS conducts and the LED connected to the drain lights UP.
b).- ENHANCEMENT, P Channel. At rest the MOS does not conduct. When you press the button, the GATE is polarized with GND, the MOS conducts and the LED connected to the drain lights UP.
c).- DEPLECTION, N Channel. At rest the MOS conducts. When you press the button, the GATE is polarized with -5V, the MOS is cut off and the LED connected to the drain turns OFF.
d).- DEPLECTION, P Channel. At rest the MOS conducts. When you press the button, the GATE is polarized with GND, the MOS conducts and the LED connected to the drain turns OFF.
