335__LOW FREQUENCY DOUBLER
Quote from Defran on December 10, 2023, 3:52 pm
335_LOW FREQUENCY DOUBLER. (Simulide R2116 or higher.)
This frequency doubler is based on converting the rising or falling edges into narrow pulses (given by the delay of the gates involved in their extraction). This doubler is designed for low frequencies, but by properly adjusting the RC network higher frequencies can be reached.SCHEME:
The rising edge pulse is obtained with an AND gate and an inverter. The falling edge pulse is obtained with a NOR gate and an inverter. Both pulses are added and applied to a T-type flipflop at whose output there is an RC delay network to obtain a widening of the output signal and make an eventual tuning with the input frequency. This structure (FF, RC delay and inverter) forms a simple monostable with rising edge triggering. An LED at the FF output acts as a monitor.
This doubler is implemented in a subcircuit added to the attached Zip. Four of its components have been set as "exposed" for adjustment from the outside to the subcircuit.
