333__UJT_UNIJUNCTION TRANSISTOR
Quote from Defran on December 2, 2023, 9:57 pm
333_UJT_UNIJUNCTION TRANSISTOR. (Simulide R2116 or higher.)
This is a small study and simulation of the UNIJUNCTION or UJT transistor. The UJT is a single PN or NP junction single transistor. It was discovered around 1953 and its use is mainly as an oscillator due to its negative resistance behavior when the emitter voltage increases. Secondly, several graphs show what has been discussed. To know more: https://www.electronics-tutorials.ws/power/unijunction-transistor.htmlSCHEME:
This scheme is based on the simulation of a UJT (here done in a subcircuit) to obtain an oscillator using the real typical circuit of this function. The signal is taken from B1, it is weak and with a DC component, Therefore, for its application it must be amplified prior to the elimination of the continuous component using a zener. At the output, an LED shows the flashing signal after a short time after connection.
