Z80 Unexpected Address Bus Behavior
Quote from notautogenerated2365 on July 30, 2025, 1:35 amI am building a simple Z80 based computer, and have a central 8-bit data bus and 16-bit address bus. My simple test scenario involves the MPU constantly loading no-op instructions (doing nothing and then incrementing the program counter). This should simply count from 0 to 65535 in binary on the address bus. I have the clock set at 1000 Hz. On the address bus, I am seeing unexpected behavior. Bits 0-6 are behaving normally, but when bits 7-16 are high, they don’t just stay high, they flash with each machine cycle. So bit 6 will be flashing back and fourth from high to low at a normal rate as it counts upwards, but bit 7 will be flashing much faster, which makes no sense. Could this be an implementation error on my part?
Quote from vranik on July 30, 2025, 6:11 pmThe Z80 CPU during M1 cycle reads the instuction from memory, but it also refresh dynamic memory. Look in the Z80 CPU datasheet how the M1 cycle looks like.
