Why ampmeter volt output doesnt works with scope?
Quote from jcbritobr on April 1, 2026, 10:35 pmHello, good evening.
Im having troubles working with an ampmeter to show its results in osciloscope. The signal is not propagating to osciloscope.
I have 5V to source/senoid with 1khz frequency.
Must have 5/100 = 0.050mA senoid in output.
May someone help?
May someone help?
Quote from arcachofo on April 2, 2026, 1:13 pmHi.
The output of Amp meter updates at low frequency, by default 20 times per second.
So it will not show a 1 KHz signal.
Quote from jcbritobr on April 2, 2026, 6:17 pmHello, thanks for your feedback. I observe that tunning the simulation fps and the simulation speed options I can put it to work but its a bit strange. Do you have any hints for simulate frequencies more than 1 khz and use oscope?
Quote from arcachofo on April 2, 2026, 6:44 pmFor voltage you can just connect oscope to any wire.
For current maybe you can use a shunt resistor and use oscope reference pin (last one), but this depends on the specific case:
