WDTCR ATtiny
Quote from yurimoisa on December 14, 2025, 2:04 pmHi
I could not update WDTCR for it has written data 00101111 from the start and not possible to update.
Is it a bug or I do something wrong?
Thanks
Hi
Thanks
Quote from yurimoisa on December 14, 2025, 7:27 pm#include <avr/interrupt.h> #define LED_BIT _BV(PB1) ISR(WDT_vect){ PORTB &= ~LED_BIT; } int main() { DDRB |= LED_BIT; // OUTPUT PORTB |= LED_BIT; cli(); GIMSK |= _BV(PCIE); wdt_reset(); WDTCR |= _BV(WDCE) | _BV(WDE); //enable write WDTCR = _BV(WDTIE) | _BV(WDP2) | _BV(WDP1); //enable interrupt + 128k cycles sei(); while (1) { } }
The app very simple, I expect that in 1 sec the led should off. Bits WDP* always 1 and no interrupt.
Thanks a lot.
ISR(WDT_vect){
PORTB &= ~LED_BIT;
int main()
PORTB |= LED_BIT;
cli();
GIMSK |= _BV(PCIE);
wdt_reset();
sei();
while (1)
Thanks a lot.
Uploaded files:Quote from arcachofo on December 16, 2025, 10:48 amQuote from yurimoisa on December 15, 2025, 6:41 pmHi
a question, this flag means WDTON fuse?
Yes, it is basically WDTON fuse.
Quote from yurimoisa on December 16, 2025, 12:49 pmok, thanks
Have you discovered why it is not possible to change WDP* bits in WDTCR? They are always "1".
ok, thanks
Quote from arcachofo on December 16, 2025, 12:51 pmQuote from yurimoisa on December 16, 2025, 12:49 pmok, thanks
Not yet.
By the way: which ATtiny are you using?
Not yet.
Quote from arcachofo on December 16, 2025, 2:03 pmThe problem comes from interrupt bit names WDTIE and WDTIF. The default for most devices is WDIE and WDIF.
You can fix it by editing the file: simulide/data/AVR/tiny13/tiny13_regs.xml
At line 32 add an alias for the bit names like this:bits="WDP0,WDP1,WDP2,WDE,WDCE,WDP3,WDTIE|WDIE,WDTIF|WDIF" />
Quote from yurimoisa on December 16, 2025, 9:49 pmHi
thanks again, now WDT works well.
The only thing is that the bits WDP are always 1 in the monitor though in fact the watch dog cycle is correct exacly as it was set in the program.
Hi
Quote from arcachofo on December 16, 2025, 10:27 pmQuote from yurimoisa on December 16, 2025, 9:49 pmThe only thing is that the bits WDP are always 1 in the monitor though in fact the watch dog cycle is correct exacly as it was set in the program.
Thank you, I will solve that issue.
