Timers and Internal interruptions on C51
Quote from GermanBueno on June 8, 2024, 10:48 pmHi,
I've got som trouble while programming in C51 the atmel 8051 uC. When it comes to using timers, I am not able to jump into the interruption, i am not sure if the simulator is able to simulate interruptions of timers overflow:
#include <reg51.h> sbit Tuds=P2^1; sbit Tdec=P2^2; sbit Tcent=P2^3; unsigned int cont_interrupt; void delay_ms(unsigned int ms){ unsigned int i; unsigned char j; for(i=1; i<ms; i++) { for(j=1; j<126; j++) { } } } void visualizacion(unsigned int number){ unsigned char decena; unsigned char unidad; unsigned char centena; unidad=number%10; decena=(number/10)%10; centena=(number/100)%10; P2 = unidad|0x20 ; delay_ms(5); P2 = decena|0x40; delay_ms(5); P2 = centena|0x10; delay_ms(5); } void RSI_tempo() interrupt 1{ TH1=0xD8; TL1=0xF0;//10000us=10us=0.01s cont_interrupt+=1; } void main(){ IE=0x8A; TMOD=0x15; //0001 0101 de esta manera el timer 0 esta como contador de eventos y el timer 1 como temporizador //Configuraion del timer 1 como temporizador TH1=0xD8; TL1=0xF0;//10000us=10us=0.01s //configuracion del timer 0 como contador de eventos TH0=0x00; TL0=0x00; TR1=1; TR0=1; cont_interrupt=0; P2=0x00; while(1){ if (cont_interrupt == 1000){ cont_interrupt=0; visualizacion(123); } } }
The circuit is the microcontroler with a multiplexed seven segment using a bcd to seven segment decoder.
Some help would be gratefull 🙂
#include <reg51.h>
sbit Tuds=P2^1;
sbit Tdec=P2^2;
sbit Tcent=P2^3;
unsigned int i;
unsigned char j;
for(i=1; i<ms; i++)
unidad=number%10;
P2 = unidad|0x20 ;
delay_ms(5);
P2 = decena|0x40;
delay_ms(5);
P2 = centena|0x10;
delay_ms(5);
TH1=0xD8;
cont_interrupt+=1;
void main(){
IE=0x8A;
TH1=0xD8;
TH0=0x00;
TL0=0x00;
TR1=1;
TR0=1;
cont_interrupt=0;
P2=0x00;
while(1){
cont_interrupt=0;
visualizacion(123);
Quote from arcachofo on June 9, 2024, 1:32 pmHi, thanks for reporting.
It's important to know which version of simulide are you using.
And I can't test your code, no idea which compiler is that and no .hex and circuit files.
The simulator can simulate interrupts.
