The HCSR04 doesn't work with the attiny2313. Rev. 2051
Quote from Lazlo_lozla on April 20, 2025, 2:00 pm"I'm trying to use the HCSR04 but I can't get it to work. I tried it this way,
and also this other way. But when I upload the program physically to my attiny2313, it works fine. I set up my terminal like this: picocom -b 4800 --parity n --data 8 --stop 1 --echo /dev/ttyUSB0.
This is my code:
#define F_CPU 1000000UL #include <avr/io.h> #include <avr/interrupt.h> #include <util/delay.h> #include "UART_LIB.h" #define NUM_MUESTRAS 5 #define TIMEOUT_MS 60 #define TIMEOUT_TICKS (F_CPU/1000*TIMEOUT_MS/8) // Para prescaler 8 // Variables globales volatile uint16_t tiempo_echo = 0; volatile uint8_t flag_captura = 0; // Interrupción de CAPTURA ISR(TIMER1_CAPT_vect) { cli(); //deshabilitar interrupciones if (TCCR1B & (1 << ICES1)) { // Flanco de SUBIDA TCNT1 = 0; TCCR1B &= ~(1 << ICES1); } else { // Flanco de BAJADA tiempo_echo = ICR1; flag_captura = 1; TCCR1B |= (1 << ICES1); } sei(); // Habilitar interrupciones } void initInputCapture() { DDRD &= ~(1 << PD6); // PD6 como entrada // Configuracion timer TCCR1A = 0; TCCR1B = (1 << ICES1)|(1 << CS11); // Flanco de subida inicial TIMSK = (1 << ICIE1); // Habilitar interrupción de captura sei(); } void triggerHC_SR04() { DDRB |= (1 << DDB7); // DDB7 como salida (Trig) PORTB |= (1 << PB7); _delay_us(10); PORTB &= ~(1 << PB7); _delay_us(2); } int main() { UART_Init(4800); initInputCapture(); float suma_total_distancias = 0; uint8_t cuenta_muestras_validas = 0; while (1) { triggerHC_SR04(); flag_captura = 0; // Reiniciar flag TCNT1 = 0; // Reiniciar Timer1 // Espera con timeout uint32_t timeout = 0; while (!flag_captura && timeout++ < TIMEOUT_TICKS); if (flag_captura) { float distancia_m = (float)tiempo_echo * 8 / 58; // Filtro de rango (2cm - 400cm) if (distancia_m >= 2 && distancia_m <= 400) { suma_total_distancias += distancia_m; cuenta_muestras_validas++; if (cuenta_muestras_validas == NUM_MUESTRAS) { float promedio = suma_total_distancias / NUM_MUESTRAS; // Enviar a UART UART_Transmit_Text("Distancia: "); UART_Transmit_Number((uint16_t)promedio); UART_Transmit_Text(" m\r\n"); suma_total_distancias = 0; cuenta_muestras_validas = 0; } }else { UART_Transmit_Text("Medicion fuera de rango\r\n"); } } else { UART_Transmit_Text("Timeout - Sin eco\r\n"); } _delay_ms(200); // Retardo adicional } }
#include "UART_LIB.h" //static char _uart_buffer_[50]; void UART_Init(uint16_t baudrate){ uint16_t regUBRR = F_CPU/(baudrate*16UL) - 1; // Cargamos los valores de BAUDRATE en los registros UBRR; UBRRH = (uint8_t) (regUBRR>>8); UBRRL = (uint8_t) (regUBRR); //Configuramos modo de operacion de 8 bits de datos; //UCSRB &= ~(1<<UCSZ2); UCSRC = (1<<UCSZ1)|(1<<UCSZ0); //Sin paridad; UCSRC &= ~( (1<<UPM1)|(1<<UPM0) ); //Modo asincrono; UCSRC &= ~(1<<UMSEL); //Habilitamos los pines Tx Rx; UCSRB = ( (1<<RXEN)|(1<<TXEN) ); } void UART_Transmit_char(uint8_t data){ // Espera a que el registro de transmisión esté vacío while (!(UCSRA & (1 << UDRE))); // Carga el dato en el registro de transmisión UDR = data; } void UART_Transmit_Text(char *texto){ while(*texto){ UART_Transmit_char(*texto); texto++; } } /*void UART_Transmit_Printf(char *str, ...){ va_list args; va_start(args,str); vsnprintf(_uart_buffer_, 50, str, args); va_end(args); UART_Transmit_Text(_uart_buffer_); }*/ void UART_Transmit_Number(uint16_t number) { if (number == 0) { UART_Transmit_char('0'); return; } char buffer[6]; // Buffer para almacenar dígitos (máximo 3 dígitos para uint8_t) uint8_t index = 0; while (number > 0) { buffer[index++] = (number % 10) + '0'; // Convierte el dígito a carácter ASCII number /= 10; } // Envía los dígitos en orden inverso for (int i = index - 1; i >= 0; i--) { UART_Transmit_char(buffer[i]); } } // Nueva función para transmitir números flotantes /*void UART_Transmit_Float(float number) { uint16_t integer = (uint16_t)number; uint16_t decimal = (uint16_t)((number - integer) * 100); UART_Transmit_Number(integer); UART_Transmit_char('.'); if(decimal < 10) UART_Transmit_char('0'); UART_Transmit_Number(decimal); }*/ bool UART_DataAvailable(void){ return ( UCSRA &(1<<RXC) ); } uint8_t UART_Receive(void) { while (!(UCSRA & (1<<RXC))); // Espera hasta que se reciba un byte completo return UDR; // Retorna el byte recibido }
#ifndef UART_LIB_H_ #define UART_LIB_H_ #define F_CPU 1000000UL #include <avr/io.h> #include <stdio.h> #include <stdarg.h> #include <stdbool.h> void UART_Init(uint16_t baudrate); void UART_Transmit_char(uint8_t data); void UART_Transmit_Text(char *texto); //void UART_Transmit_Printf(char *str, ...); void UART_Transmit_Number(uint16_t number); //void UART_Transmit_Float(float number); bool UART_DataAvailable(void); uint8_t UART_Receive(void); #endif /* UART_LIB_H_ */
#makefile attiny2313 AVR = attiny2313 COMPILAR = avr-gcc -Wall -O3 -mmcu=$(AVR) FUENTES = 019sensorUltrasonidoHCSR04.c UART_LIB.c SALIDA_HEX = 019sensorUltrasonidoHCSR04.hex OBJETOS = $(patsubst %.c, %.o, $(FUENTES)) SALIDA_ELF = $(patsubst %.hex, %.elf, $(SALIDA_HEX)) all: $(SALIDA_HEX) size # <-- Añade 'size' como dependencia %.o: %.c $(COMPILAR) -c $< $(SALIDA_HEX): $(OBJETOS) $(COMPILAR) $^ -o $(SALIDA_ELF) avr-objcopy -O ihex $(SALIDA_ELF) $@ # Comando para verificar el tamaño del firmware .PHONY: size size: $(SALIDA_ELF) @echo "=== Tamaño del firmware ===" avr-size --mcu=$(AVR) --format=avr $(SALIDA_ELF) clean: rm -f *.o *.elf *.hex
#makefile attiny2313 AVR = attiny2313 PUERTO = /dev/ttyUSB0 PROGRAMADOR = arduino BAUD = 19200 COMPILAR = avr-gcc -Wall -O3 -mmcu=$(AVR) FUENTES = 019sensorUltrasonidoHCSR04.c UART_LIB.c SALIDA_HEX = 019sensorUltrasonidoHCSR04.hex OBJETOS = $(patsubst %.c, %.o, $(FUENTES)) SALIDA_ELF = $(patsubst %.hex, %.elf, $(SALIDA_HEX)) all: $(SALIDA_HEX) %.o: %.c $(COMPILAR) -c $< $(SALIDA_HEX): $(OBJETOS) $(COMPILAR) $^ -o $(SALIDA_ELF) avr-objcopy -O ihex $(SALIDA_ELF) $@ .PHONY: limpiar limpiar: rm -f *.o *.elf *.hex .PHONY: subir subir: $(SALIDA_HEX) avrdude -P $(PUERTO) -c $(PROGRAMADOR) -p $(AVR) -b $(BAUD) -U flash:w:$<
<circuit version="1.1.0-SR1" rev="2051" stepSize="1000000" stepsPS="1000000" NLsteps="100000" reaStep="1000000" animate="1" > <item itemtype="MCU" CircId="tiny2313-1" mainComp="false" Show_id="false" Show_Val="false" Pos="-124,-40" rotation="0" hflip="1" vflip="1" label="tiny2313-1" idLabPos="0,-20" labelrot="0" valLabPos="-16,20" valLabRot="0" Frequency="1 MHz" Program="019sensorUltrasonidoHCSR04.hex" Auto_Load="false" saveEepr="true" Logic_Symbol="false" Rst_enabled="false" Ext_Osc="false" Wdt_enabled="false" varList="PORTB,DDRB,flag_captura,tiempo_echo" MainMcu="true" SerialMon="-1" /> <item itemtype="SR04" CircId="SR04-2" mainComp="false" Show_id="false" Show_Val="false" Pos="-76,-100" rotation="0" hflip="1" vflip="1" label="SR04-2" idLabPos="-16,-48" labelrot="0" valLabPos="-16,20" valLabRot="0" /> <item itemtype="SerialTerm" CircId="SerialTerm-6" mainComp="false" Show_id="false" Show_Val="false" Pos="-168,-24" rotation="0" hflip="-1" vflip="1" label="SerialTerm-6" idLabPos="-20,-32" labelrot="0" valLabPos="-16,20" valLabRot="0" Baudrate="4800 _Bd" DataBits="8 _bits" StopBits="1 _bits" SerialMon="false" /> <item itemtype="Voltage Source" CircId="Voltage Source-7" mainComp="false" ShowProp="MaxValue" Show_id="false" Show_Val="true" Pos="-200,-100" rotation="0" hflip="1" vflip="1" label="Voltage Source-7" idLabPos="-32,-48" labelrot="0" valLabPos="-8,30" valLabRot="0" Running="false" Value_Volt="3.785 V" MaxValue="5 V" MinValue="0 V" /> <item itemtype="Connector" uid="Connector-9" startpinid="tiny2313-1-PORTD6" endpinid="SR04-2-outpin" pointList="-84,40,-68,40,-68,-52" /> <item itemtype="Connector" uid="Connector-24" startpinid="tiny2313-1-PORTD1" endpinid="SerialTerm-6-pin1" pointList="-132,-16,-144,-16" /> <item itemtype="Connector" uid="Connector-49" startpinid="SR04-2-trigpin" endpinid="tiny2313-1-PORTB7" pointList="-76,-52,-76,-24,-84,-24" /> <item itemtype="Connector" uid="Connector-50" startpinid="Voltage Source-7-outPin" endpinid="SR04-2-inpin" pointList="-172,-84,-172,-124,-164,-124" /> <item itemtype="Connector" uid="Connector-51" startpinid="tiny2313-1-PORTD0" endpinid="SerialTerm-6-pin0" pointList="-132,-24,-144,-24,-144,-32" /> </circuit>
This is my code:
#include <avr/io.h>
TCNT1 = 0;
tiempo_echo = ICR1;
flag_captura = 1;
TCCR1A = 0;
sei();
_delay_us(10);
_delay_us(2);
int main() {
UART_Init(4800);
initInputCapture();
while (1) {
triggerHC_SR04();
if (flag_captura) {
// Enviar a UART
}else {
} else {
//Sin paridad;
//Modo asincrono;
UDR = data;
while(*texto){
texto++;
va_list args;
va_start(args,str);
va_end(args);
if (number == 0) {
return;
uint8_t index = 0;
number /= 10;
#ifndef UART_LIB_H_
#define UART_LIB_H_
#include <avr/io.h>
#include <stdio.h>
#include <stdarg.h>
AVR = attiny2313
%.o: %.c
$(COMPILAR) -c $<
.PHONY: size
clean:
AVR = attiny2313
BAUD = 19200
all: $(SALIDA_HEX)
%.o: %.c
$(COMPILAR) -c $<
.PHONY: limpiar
limpiar:
.PHONY: subir
</circuit>
Quote from arcachofo on April 21, 2025, 9:54 amHi.
It would be much easier for both if you just zip the folder containing the files and attach here.
Quote from arcachofo on April 23, 2025, 10:02 amSeems that the Input Capture Unit is missing the falling edge. I will have a look.
Quote from arcachofo on April 26, 2025, 2:18 pmHi.
I think this should be solved in last tester build for 1.1.0:
Quote from Lazlo_lozla on April 27, 2025, 1:23 pmI tested the HC-SR04 in rev2069, and it's now working properly. Thank you.
