Swapped Current Controlled and Use Control Pins of Controlled source properties
Quote from vranik on March 9, 2024, 4:37 amHi,
the property Use Control Pins of Controlled source is below the property Current Controlled. When the Use Control Pins is unchecked the Current Controlled property is hidden and the Use Control Pins property change position. It would be nice to swap this two options to achieve their permanent position in properties window.
By the way the gain of the controlled source also has unit. It is V/V, V/A, A/V or A/A accoring to selected configuration.
Tested trunk revision 2244
Quote from arcachofo on March 9, 2024, 4:09 pmIt would be nice to swap this two options to achieve their permanent position in properties window.
Yes, that's a good idea.
