Support for Watch Dog Timer ?
Quote from Gururaj on April 18, 2025, 2:57 amHi All,
First of all, thanks for providing SimulIDE . Its very useful and awesome simulator!
I am using it for a circuit that uses PIC16F72 (Though this uC is not supported, I was able to use p16F873-2). I am stuck at simulating Sleep and wakeup by Watch Dog Timer (WDT) on any PIC in SimulIDE.
Note : On the physical uC PIC16F72 WDT is working fine.
I have written small program (Attached) to try WDT with p16F627-10 (As it has Enable WD in its Properties->config) But as soon as I start the simulation, following message is show repeatedly in the console and nothing works.
McuWdt::runEvent - Watchdog Reset
But the same program is working as expected in MPLAB X IDE 6.25's Simulator.
Any suggestion would be highly appreciated.
Thanks in Advance.
-Guru
Hi All,
Thanks in Advance.
-Guru
Uploaded files:Quote from Gururaj on April 18, 2025, 1:06 pmHi @arcachofo,
Thanks for the reply. Please find the attached hex file for the same.
Regards,
-Guru
Hi @arcachofo,
Regards,
-Guru
Uploaded files:Quote from arcachofo on April 18, 2025, 3:00 pmThank you.
Fixed and re-uploaded files at rev 2061:
Quote from Gururaj on April 18, 2025, 4:35 pmHi @arcachofo,
Wow, that was pretty quick. Thank you so much. Working absolutely fine. Apologies if I am calling with a wrong name.
I need a suggestion. Since 16F72 was missing I used 16F873 for my simulation. But 16F873 is missing Watch Dog Timer in Config window. Hence just for simulating WDT I am using PIC16F627 as it has Enable WDT in config window as shown in the attached image. Is there a way to enable WDT for 16F873? Please suggest.
Thanks and Regards,
Guru
Hi @arcachofo,
Thanks and Regards,
Guru
Uploaded files:Quote from arcachofo on April 18, 2025, 5:50 pmQuote from Gururaj on April 18, 2025, 4:35 pmHi @arcachofo,
You can fix 16F873 Watchdog.
Open file in Editor: data/PIC/p16F87x/p16F87x_perif.xml
And add these lines before configwords and save:
<wdt name="WDT" configregsA="OPTION" prescalers="1,2,4,8,16,32,64,128"/>The end of the file should look like this:
<spi name="SPI" configregsA="SSPCON" dataregs="SSPBUF" statusreg="SSPSTAT" interrupt="SSP" prescalers="4,16,64,0" pins="PORTC5,PORTC4,PORTC3,PORTA5"/><!-- "SD0,SDI,SCK,SS" --> </msspunit> <wdt name="WDT" configregsA="OPTION" prescalers="1,2,4,8,16,32,64,128"/> <configwords name="cfgWord" type="02"> <word name="COINFIG1" address="0x2007" value="0xFF" /> <word name="COINFIG2" address="0x2008" value="0xFF" /> </configwords> </parts>
dataregs="SSPBUF"
statusreg="SSPSTAT"
interrupt="SSP"
</msspunit>
</configwords>
</parts>
Quote from Gururaj on April 18, 2025, 6:29 pmThanks for the suggestion. That got me the WDT for 16F873.
But CLRWDT() or __asm("clrwdt") is not honored and as per the configuration every 2.3 seconds 16F873 is getting reset (
McuWdt::runEvent - Watchdog Reset) even if CLRWDT() or __asm("clrwdt") is called within 100 msecs.
Its not the issue with only 16F873. But even in PIC16F627 same issue is happening. I have attached a Blink.c, Blink.Hex and Blink.sim1 files for your reference. If CLRWDT() or __asm("clrwdt") is honored, LED should blink 5 times with a delay of 500 msec. Almost at 1.5 Secs, uC is reset with WDT. Can CLRWDT() be considered in any way? Please suggest.
Thanks and Regards,
Gururaj
Thanks and Regards,
Gururaj
Quote from arcachofo on April 18, 2025, 8:22 pmBut CLRWDT() or __asm("clrwdt") is not honored and as per the configuration every 2.3 seconds 16F873 is getting reset (
Yes, it would be good that we could clear the watchdog...
I think it is solved, but I'm not going to build for all OS.
Here you have Windows 64 version to test it: SimulIDE_1.1.0-16F72.zipBTW: I added PIC16F72, but I didn't test it at all, feel free to give it a try.
Quote from Gururaj on April 19, 2025, 6:34 amIts working absolutely fine now. I used Pic16F72 and working as expected along with WDT. Thank you so much.
Regards,
Gururaj
Regards,
Gururaj
