Simulide problem reset mclr
Quote from twister1970 on October 20, 2024, 8:56 amThe MCLR pin is connected to the 5 volt power supply via a 10 Kohm resistor. For the reset there is a button connected to the mclr pin and to the circuit ground. When I press the button the reset occurs but as soon as I release the button the program starts directly.
Quote from arcachofo on October 20, 2024, 9:05 amHi.
Sorry but I don't understand what is the problem.
I expect that the program starts after the Reset condition ends.Can you elaborate in what is exactly the problem?
Quote from twister1970 on October 20, 2024, 9:22 amWith other simulators when I reset with the button the program stops and I have to restart it while with simulide as long as I hold down the reset button the program stops but as soon as I release the reset button the program restarts by itself.
Quote from arcachofo on October 20, 2024, 9:42 amas long as I hold down the reset button the program stops but as soon as I release the reset button the program restarts by itself.
As far as I know that is how it works in real life.
Quote from twister1970 on October 20, 2024, 10:07 amok thanks. With a demo version of proteus instead it stops the program and I have to restart it. Thanks a lot for the help.
Quote from KerimF on October 20, 2024, 2:19 pmQuote from arcachofo on October 20, 2024, 9:42 amAs far as I know that is how it works in real life.
As far as I know too.
Quote from twister1970 on October 20, 2024, 4:10 pmThe pic's MCLR pin, once connected to ground via a button, should reset the pic and restart the program. The program in question uses a button to start. Using Simulide, the pic resets and the program restarts without waiting for the start button to be pressed. I'll try to test everything on a breadboard.
Quote from arcachofo on October 21, 2024, 7:35 amMaybe I don't understand correctly.
Is there another button appart from the reset button?
