MenuForum NavigationForumLast PostsSubscriptionsProfileForum breadcrumbs - You are here:ForumGeneral: General Discussion about SimulIDESimulation must be stopped if har …You need to log in to create posts and topics.Simulation must be stopped if hardware change occured.sydhsnazm@sydhsnazm3 Posts#1 · June 22, 2024, 11:27 amQuote from sydhsnazm on June 22, 2024, 11:27 amstrangely, the simulation continues even if we change hardware. strangely, the simulation continues even if we change hardware. arcachofo@arcachofo957 Posts#2 · June 22, 2024, 11:48 amQuote from arcachofo on June 22, 2024, 11:48 amHi.Which change of hardware does not stop simulation? Hi.Which change of hardware does not stop simulation? sydhsnazm@sydhsnazm3 PostsTopic Author#3 · June 22, 2024, 12:38 pmQuote from sydhsnazm on June 22, 2024, 12:38 pmhey, removing power rails while mega8 is being simulated. thanks hey, removing power rails while mega8 is being simulated. thanks arcachofo@arcachofo957 Posts#4 · June 22, 2024, 1:11 pmQuote from arcachofo on June 22, 2024, 1:11 pmRemoving power rails stops the simulation. Which version of simulide are you using? Removing power rails stops the simulation. Which version of simulide are you using? Post Reply: Simulation must be stopped if hardware change occured. CancelRSS Feed
