Shields not working in 1.1.0
Quote from nils on February 24, 2024, 10:54 amGood Morning,
I want to report a bug in the new unstable Version 1.1.0, in which the usage of Shields isn't working anymore.
Also, is there any SimulIDE Version including scripted components as well as a functioning use of shields?
Thanks for the help.
Good Morning,
Quote from arcachofo on February 24, 2024, 11:49 amHi.
I think that issue is solved in Rev 2194.
You can download it here (trunk): https://simulide.com/p/testers/
Quote from TimFisch on February 25, 2024, 3:07 amHmm... I just tried the SimulIDE-R2194_Win64 version in a clean Win10 VM but it seems to have still some issues.
My test was as follows:
- adaptation of the display-shield: ...\data\shields\LcdShield\LcdShield.sim1 :
- tunnel for EN pin of Hd44780 renamed to 11
- tunnel for RS pin of Hd44780 renamed to 12
- shield saved, simulIDE restarted
- test with display example: ...\examples\Outputs\Displays\hd44780\lcd_hd44780.sim1
- drag'n'drop of Lcd Shield from component sidebar
- Attaching to Arduino
- Start of simulation
Result: The original display in lcd_hd44780.sim1 shows "No Cursor" and so on, but the one on the Lcd Shield does not.
The described test works fine for SimulIDE_1.0.0-SR2_Win64 (R1449). In this "stable" version, both displays show the text.
Quote from arcachofo on February 25, 2024, 7:35 amI just tried the SimulIDE-R2194_Win64 version in a clean Win10 VM but it seems to have still some issues.
Hi Tim.
You are right, there are some issues.
I tried opening an old example and it worked, but if I create new one it does not work at all.
In addition if I save it the shield is not saved.I'm working in it.
I will also add some examples (shields folder is empty).
Hi Tim.
I'm working in it.
Quote from TimFisch on February 25, 2024, 8:10 pmHi arcachofo,
sounds good. Could you put a trial version in the "Last builds for testing"?
Nils is a student of mine and eager to implement some Hookups 🙂
Hi arcachofo,
Quote from arcachofo on February 25, 2024, 8:41 pmQuote from TimFisch on February 25, 2024, 8:10 pmHi arcachofo,
Nils is a student of mine and eager to implement some Hookups 🙂Yes, I had plan to do it even before this bug report.
Just check a few things and It will be updated.
