Sensor component creation
Quote from Christian on November 11, 2024, 5:49 pmHello,
Just for my information -
Is there a documentation of what is needed to created a new sensor component - or what would be the best method in short ?
Quote from arcachofo on November 13, 2024, 3:40 pmHi.
There are many ways to create a component.
If you explain what do you want I can suggest some way to do it.
Quote from Christian on November 14, 2024, 8:41 am
Ah ok 🙂
I was wondering about having the MCP9808 temperature sensor ; the ds1621 is pratically nowhere to be found on the market nowadays. The MCP9808 has basically the same pins layout, also use an I2C bus, but different registers and a better resolution. I had a look at the source file, but could not figure out how it was integrated in the "big picture".
Ah ok 🙂
Quote from arcachofo on November 15, 2024, 10:24 pmThat one could be done with an Script, but it is not posible to do with the current implementation.
I added some functions that will allow to do it.
I need to do some testing and when it is working I wiil let you know.
Quote from arcachofo on November 27, 2024, 11:38 amHi.
I uploaded some templates for script components:
https://simulide.com/p/forum/topic/tester-builds-1-2-0/#postid-1601There is one for TWI that can be used to create MCP9808 temperature sensor.
If you try it and have any questions just let me know.Note that version 1.2.0 is needed:
