Segm fault with avr pin change interrupt
Quote from steinm on December 6, 2023, 11:13 amWhenever I turn on the PCINT(0) interrupt in my firmware, simulide segm faults. Here is the gdb backtrace. Do you need more information for fixing this?
Circuit Matrix looks good
FPS: 20 Frames per SecSpeed: 100 %Speed: 1000000000000 ps per Secps/Fr: 50000000000 ps per FrameNonLi: 100000 Max Iterations
Simulation Running...
Thread 9 "Thread (pooled)" received signal SIGSEGV, Segmentation fault.[Switching to Thread 0x7fffe8ff96c0 (LWP 2636794)]0x00000000004ec8e9 in McuPort::pinChanged (this=0x11c1a70, pinMask=<optimized out>, val=<optimized out>)at ../src/microsim/mcuport.cpp:4949 if( m_intMask & pinMask ) m_interrupt->raise(); // Pin change interrupt(gdb) bt#0 0x00000000004ec8e9 in McuPort::pinChanged(unsigned char, unsigned char)(this=0x11c1a70, pinMask=<optimized out>, val=<optimized out>) at ../src/microsim/mcuport.cpp:49#1 0x00000000004fec13 in Simulator::solveCircuit() (this=this@entry=0x131b130)at ../src/simulator/simulator.cpp:203#2 0x00000000004fa288 in Simulator::runCircuit() (this=0x131b130) at ../src/simulator/simulator.cpp:170#3 Simulator::runCircuit() (this=0x131b130) at ../src/simulator/simulator.cpp:145#4 0x00000000004fe955 in non-virtual thunk to QtConcurrent::RunFunctionTask<void>::run() ()at /usr/include/x86_64-linux-gnu/qt5/QtConcurrent/qtconcurrentrunbase.h:133#5 0x00007ffff68de122 in () at /lib/x86_64-linux-gnu/libQt5Core.so.5#6 0x00007ffff68daeb1 in () at /lib/x86_64-linux-gnu/libQt5Core.so.5#7 0x00007ffff62a63ec in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:444#8 0x00007ffff6326a5c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81(gdb)
FPS: 20 Frames per Sec Speed: 100 % Speed: 1000000000000 ps per Sec ps/Fr: 50000000000 ps per Frame NonLi: 100000 Max Iterations
Quote from arcachofo on December 6, 2023, 11:47 amI can't reproduce the issue.
Can you share an example that triggers the segfault?For example this code this code works ok in atmega328:
#include <avr/interrupt.h> int main(void) { DDRB= 0b00001000; PORTD=0b00000001; PCICR |= 1<<PCIE2; PCMSK2 |= 1; sei(); while(1){}; } ISR(PCINT2_vect) { PORTB ^= 1<<3; }
int main(void)
DDRB= 0b00001000;
PORTD=0b00000001;
PCICR |= 1<<PCIE2;
PCMSK2 |= 1;
sei();
while(1){};
ISR(PCINT2_vect)
PORTB ^= 1<<3;
Quote from steinm on December 6, 2023, 2:47 pmAttached is a simulation and firmware for an attiny85 at 1 Mhz. The capacity voltage rise and once it has reached the high level the PCINT4 triggers which makes simulide segmfault
Uploaded files:Quote from arcachofo on December 6, 2023, 3:02 pmThanks, I can reproduce this one.
There is an error in a config file:
data/AVR/tinyx5/tinyx5_perif.xml
At line 8: name="PCINT" should be name="PCINT0"
