Repeated Question, Did Someone Build an Ideal or Real VCO Model?
Quote from KerimF on November 5, 2024, 11:54 amI was looking for an ideal VCO (Voltage Controlled Oscillator) model about 2 years ago.
I mean by an ideal VCO, a mathematical model whose symbol has one input (voltage) and one output (squarewave). And it is likely defined by three parameters in the least:
[1] Its gain (output frequency / input voltage), Hz / V
[2] Its lowest frequency (Fmin) when Vin = 0V
[2] Its highest frequency (Fmax) when Vin = 1V (or any other voltage)
Arcachofo (the creator of simulIDE) showed me in detail how it could be done:
https://simulide.forumotion.com/t1185-equivalent-to-cd4046-phase-locked-loop#5244
But I couldn’t make it 🙁 Then, I forgot about it because a VCO is usually not used in applications that need to be simulated by simulIDE.
But now, I am just curious to know if a certain VCO model was added, likely by an expert user of simulIDE, during the last 2 years.
Quote from arcachofo on November 5, 2024, 12:53 pmNow it is much easier to make an VCO, but I think you are using an older version of Simulide.
Have you tried version 1.1.0-SR1?
Quote from KerimF on November 5, 2024, 4:23 pmThe newest versions, I heard of and downloaded, are SimulIDE_1.1.0-R1973_Win32 and SimulIDE_1.1.0-SR0_Win32.
Quote from arcachofo on November 5, 2024, 9:23 pmThere is also 1.1.0-SR1:
https://simulide.com/p/simulide-1-1-0-sr1-stable-release-1-available-for-download/
Quote from KerimF on November 7, 2024, 11:13 amQuote from arcachofo on November 5, 2024, 12:53 pmNow it is much easier to make an VCO, but I think you are using an older version of Simulide.
I have it now. But I am not sure what to try.
I never wrote a script (or the like) because I couldn't download any advanced compiler to run it and become familiar to how to use it.
When necessary, I simply use the very old *.bat for DOS or write a DOS program in C language (compiled by BorlandC 3.1).
