Reading from PGM returns 65535 instead of 255
Quote from steinm on December 14, 2023, 11:51 amWhen reading from an unitialized PGM a value of 0xff will read as 65535. Once it was set to 255 it will return 255. From within the MCU Monitor you cannot tell if a value was explicitly set or not, but reading a byte shouldn't return a value > 255 anyway.
I read from PGM in a reset() function
cych = component.readPGM( PC++ );
Quote from arcachofo on December 14, 2023, 12:10 pmbut reading a byte shouldn't return a value > 255 anyway.
That depends on the PGM word size.
You should set: progword="1" in the definition file if you want only 1 byte.
Quote from steinm on December 14, 2023, 12:53 pmIt's actually set and reading from PGM returns single bytes just like expected, but only if the value in PGM was set before.
Quote from steinm on December 14, 2023, 4:20 pmLooks like it's getting worse. Now
component.readPGM( PC++ );returns 1 instead of 65535
Looks like it's getting worse. Now component.readPGM( PC++ ); returns 1 instead of 65535
