PIC16F887 PORTA problem
Quote from wolleDD on September 2, 2025, 11:58 amHi together,
I tried to use a PIC16F887 PORTA as output. I set all needed configurations (in my opinion), such as:
FOSC in CONFIG1 as INTOSCIO (RA6/RA7 for IO),
OSCCON = 0b01110101; // OSC settings
ADCON0bits.ADON = 0; // ADC off
ADCON1 = 0x00; // Vref internal
ANSEL = 0x00; // PORTA analog off
ANSELH = 0x00; // PORTB/E analog off
CM1CON0bits.C1ON = 0; // Comperator 1 off
CM2CON0bits.C2ON = 0; // Comperator 2 offand at last TRISA = 0x00; // PortA for output
But if I set PORTA = 0xFF, only bits 0..5 are set.
Can help anyone to find my mistake? Thank you very much!
Hi together,
Quote from arcachofo on September 7, 2025, 2:07 pmHi, thanks for reporting.
I'm not at my computer now, so I'm very limited, but if you share your hex file I can try to find what is happening.
Quote from wolleDD on September 11, 2025, 9:11 amHello arachofo,
sorry for my late replay. I send you attached a zip file with the hex file, the C source and the sim file.
The example here is only toggling PORTA, but RA6 and RA7 doesn’t work.
Best regards
Hello arachofo,
Best regards
Uploaded files:Quote from arcachofo on September 15, 2025, 10:29 amThanks for the files, but seems that the hex file does not match the source code, PORTA is doing nothing.
