PIC12F683 CCP1 compare mode
Hello again,
Also I can see a strange behaviour with CCP1 compare mode, still with 12F683 PIC.
I use the following register to toggle CCP1 pin (GP2) :
1000 = Compare mode, set output on match (CCP1IF bit is set)
1001 = Compare mode, clear output on match (CCP1IF bit is set)
In debug mode, the toggle occurs every 93ms, which is expected with :
CCPR1H = 0b01011010; // CCPR1 = 0x5AEE = 23278 ticks = 0,025ms w/o prescaler
CCPR1L = 0b11101110; // TMR1 registers will be compared with these registers
T1CONbits.TMR1CS = 0; // TMR1 with internal Clock source FOSC/4 = 1µs
T1CONbits.T1CKPS = 0b10; // Prescale 1:4 => 1 TMR1 tick = 4 µs
In SimulIDE, TMR1 never increments up to CCPR1 ; it seems CCP1IF flag is stuck to 1 and is never reset to 0, despite the code.
Hi, thanks for all the testing.
This and capture mode are hopefully fixed.
You can test it using this build (Windows64): SimulIDE_1.1.0-260104_test.zip
Let me know if it doesn't work for you or there are more problems.
Thank you for your quick answer ! The period is good, but the duty cycle a bit strange ; see screenshot :
In debug mode, it seems like when CCP1M<3:0>: CCP Mode Select bits are set to :
it does not wait for CCP1IF bit set and immediately clear output.
When set to 1000, it does wait for CCP1IF bit and then set CCP1 pin.
I changed the code for :
        while (!PIR1bits.CCP1IF);
        PIR1bits.CCP1IF = 0;
        CCP1CONbits.CCP1M = 0b1000; // OC pin set (GP2) at next match
        TMR1L = 0x00;
        TMR1H = 0x00;
        CCP1CONbits.CCP1M = 0b1001; // OC pin cleared (GP2) at next match
        TMR1L = 0x00;
        TMR1H = 0x00;
So timers are OK and match correctly, the CCP1IF bit is set accordingly, but maybe a problem with 0b1001 mode ?
Or maybe my code is wrong or I did not understand the datasheet correctly.
You are right, there is a problem with the output pin cleared every time the mode is changed.
I will upload new builds with fixes soon.
