Oscope reference Pin
Quote from timathis on May 12, 2025, 2:25 amWhat is the function or purpose of the reference pin?
Is is a fixed standard voltage value to be used as an output?
Does it have any rellavence to ground reference?
Quote from KerimF on May 13, 2025, 1:56 amThe reference pin of the scope is an input pin.
It is used when one likes to display the voltage between two nodes instead of between a node and ground.
In this case, one of the two nodes could be assumed as being the reference one for the scope by connecting it to its reference pin.
Hope this helps.
Hope this helps.
Quote from timathis on June 1, 2025, 1:50 pmThanks for the response.
So it looks like it is a way to simulate a non grounded differential scope input.
