Missing minimum current in current source properties
Quote from vranik on March 9, 2024, 4:06 amHi,
there is possible to set current voltage, maximum voltage and minimum voltage for the voltage source. The current source has only properties current current and maximum current. The property minimum current is missing.
Tested trunk revision 2244
Quote from arcachofo on March 9, 2024, 3:49 pmYes, this is not implemented.
And I don't want to make changes if not absolutely needed, specially if it adds strings to translations.
