Missing empty directory when using git
Quote from TomaSajt on December 13, 2023, 9:08 pmWhen I was playing around with the build-steps of the application, I initially used
git, and cloned the source code fromhttps://git.launchpad.net/~arcachofo/simulide/, because I didn't have access tobzr. It turns outgitdoesn't support committing empty directories, soresources/qmwasn't cloned to my system. Because of this the build failed (the directory didn't exist, and it tried to place files inside of it). This is a very minor issue as I doubt a lot of people would use git to clone the project. Just wanted to put this out there.
When I was playing around with the build-steps of the application, I initially used git, and cloned the source code from https://git.launchpad.net/~arcachofo/simulide/, because I didn't have access to bzr. It turns out git doesn't support committing empty directories, so resources/qm wasn't cloned to my system. Because of this the build failed (the directory didn't exist, and it tried to place files inside of it). This is a very minor issue as I doubt a lot of people would use git to clone the project. Just wanted to put this out there.
