MacOS M1 Arduino IDE - Can't find a path that will stick to Compiler settings
Quote from Crunchysteve on December 22, 2023, 12:18 amIn IDE 2, there's no access to the compiler in the GUI app (as I understand it), so I have the arduino-cli compiler installed at ~/bin/arduino-cli, as per Arduino's instructions, have verified this by running "~/bin/arduino-cli --help" in Terminal, getting all the useful info that confirms the cli is actually install.
I have tried adding the path to the binary in the standard GUI ArduinoIDE as well as ~/bin/arduino-cli, either "fall out" of the field the second I tab or click to the libraries path. "/bin/ardino-cli" doesn't work as there is no install there, it's local only.
Any ideas?
Any ideas?
Uploaded files:Quote from arcachofo on December 22, 2023, 12:51 pmArduino compiler will not work in simulide that way, it expect everything inside the Arduino folder as you download it.
For me this works:
Tool path: /Applications/Arduino IDE.app/Contents/
For me this works:
Quote from Crunchysteve on December 22, 2023, 9:15 pmThanks for your quick reply, appreciated. Sadly, it hasn't solved my problem. That was the first path I tried when I first installed SimulIDE.
That path and any other path to any version of Arduino IDE won't stick, and I can't even navigate to using the "..." button.
Quote from arcachofo on December 22, 2023, 9:30 pmDid you try introducing the path manually? (don't forget the last slash)
No... seems that that is not considered a folder.
Quote from Crunchysteve on December 22, 2023, 9:56 pmI've tried with the slash, without the slash, pasting manually, using the "..." button, tried ArduinoIDE/Content, tried ~/bin/arduino-cli nothing will stick. As soon as I tab to the Libraries field or click the window away, the entry in the Tool Path field vanishes.
Quote from arcachofo on December 22, 2023, 10:04 pmAs soon as I tab to the Libraries field or click the window away, the entry in the Tool Path field vanishes.
That is probably because the arduino-cli executable is not found.
Assuming that you are using Arduino IDE 2.2.1, can you confirm that arduino-cli exist in this path? :
/Applications/Arduino IDE.app/Contents/resources/app/lib/backend/resources/arduino-cli
Quote from Crunchysteve on December 22, 2023, 10:35 pmExcept they are verified as there and both the Arduino IDE and the CLI versions run. 30 years chasing signal path faults before I retired 😉 Still, I get that we all make mistakes. You're right to check.
Quote from arcachofo on December 22, 2023, 10:43 pmMaybe is about the version of simulide you are using...
Which version are you using?
EDIT: I see... you are using 1.1.0-RC0, the problem is definitely here.
1.1.0-RC0 does not support Arduino IDE 2.2Or directly try 1.0.0-SR2_MacOs :
https://launchpad.net/simulide/1.0.0/1.0.0-sr2/+download/SimulIDE_1.0.0-SR2_MacOs.zip
Quote from Crunchysteve on December 22, 2023, 11:54 pm1.1.0-RC0 R1909, downloaded the day before yesterday from here. Maybe I'll retrograde to 1.0.0, see if that works.
Quote from arcachofo on December 23, 2023, 12:03 am1.0.0-SR2 was released on December 21.
For some reason I assumed that you were reporting about that version.1.1.0-RC1 with support for Arduino 2.2 will be released in a few days (hopefully).
