Load/Save dialog box takes tooooo long to open
Quote from blitobyte on September 3, 2024, 11:03 amHi,
I use Debian 11, and lately I've observed SimulIDE takes about 30 seconds to open the Load/SaveAs dialog boxes. First I only get the square border of the dialog, then the content although the box is irresponsive. Clinking on any of the files is impossible. Then, finally, the dialog box becomes operative, but moving up or down in the tree file is a nightmare. After about 30 seconds the system becomes responsive. Looks like a memory problem, but this doesn't happen with other programs.
Anybody else the same problem? I use SimulIDE 1.1
Quote from electrodudimanche on September 18, 2024, 8:14 amGot this problem on openSuse with many programs, I narrowed it down to program using QT.
Looks like there's also problems between QT and KDE plasma recently ( plasmashell crashing ).I suspected first the problem with my drives since I installed a new one... But looks like it's not the problem.
I also see CPU utilization up by quite a bit and sometimes openSuse just kill the process.
Quote from blitobyte on September 20, 2024, 4:29 pmHi, thanks for answering!
I only have this problem with SimulIDE. In fact, I ran the top command along with SimulIDE and I got percentages of use over 100% (128%, 134%...).
It's true that some time ago I upgraded my Debian 10 to 11 and upgraded QT. It might be that. I didn't have this problem before (I think)
On the other hand I use SimulIDE AppImage.
