Limited model of Acid Battery
Quote from KerimF on September 7, 2024, 1:15 pmHi,
It is about a very limited model of an acid battery. It is based on the following approximated calculations:
Capacity [Q, AH]: 100 AH
Discharge current [I, A]: 20 A
Discharge time [Q/I. sec]: Q/I = 5 h = 18,000 sec
Initial voltage [V]: 24 V
End of discharge voltage [V]: 20 V
During the discharge time, the battery acts as a capacitor C and a voltage source (20V) in series:
C = I * dt / dv = 20 * 18000 / (24-20) = 180,000 FOn the schematic (AcidBattModel_1.sim1, attached), I got 0V instead of 24V (Vbatt=20V + initial Vc=4V).
I tested it with SimulIDE-R2259_Win32. I might have missed something.
Kerim
Kerim
Quote from KerimF on September 7, 2024, 1:46 pmThank you again for your prompt reply.
Usually when I try making a connection and there was already a hidden one at a node, simulIDE refuses to add a new track.
I wonder now how I was able to fool simulIDE 🙂 by making multi traces between those two nodes!Â
