LAnalizer problems exporting VCD of bus
Quote from kopesetic on October 17, 2025, 2:23 pmHello,
I used the mcs51_extPGM.sim1 as a start point for my simulation. It was very helpful.
My goal is to record the activity on the bus for an 80C32 device in a VCD file.
When I use the LAnalizer, the view on the screen is of the bus. However when I use the export function the VCD file seems to be a problem. GTKwave reports an error. The header section seems to indicate that only one pin of the bus is being recorded.
The format of the VCD file itself is not what I would expect.
I am attaching a zip with my example.
Thanks for your thoughts
Quote from kopesetic on October 17, 2025, 6:30 pmUnderstood.
Is there a way to increase the number for probes on the LAnalizer?Or can I use more than one LAnalizer in my circuit?
I need 8 bits of P0 & ALE as a minimum.
Understood.
