How to compile SimulIDE?
Quote from francisco4ever on November 25, 2024, 12:02 amHow to compile SimulIDE??? On QT or even on the console for Windows?
Quote from arcachofo on November 25, 2024, 4:54 amHi.
You can compile Simulide like any other Qt application.
Using QT Creator or in a terminal cd to build_XX folder, then:$ qmake
$ makeYou must install all depenedencies:
- Qt5Core
- Qt5Gui
- Qt5Xml
- Qt5svg
- Qt5Widgets
- Qt5Concurrent
- Qt5 Multimedia
- Qt5 Multimedia Plugins
- Qt5 Serialport
$ qmake
$ make
- Qt5Core
- Qt5Gui
- Qt5Xml
- Qt5svg
- Qt5Widgets
- Qt5Concurrent
- Qt5 Multimedia
- Qt5 Serialport
Quote from Deleted user on December 19, 2024, 5:17 amHi. In old forum I believe I have created some detailed compilation guide, but I can't find it anymore.
I recently realized that there is new forum as I didn't used this project for a long time...
Edit: I have found it.
https://simulide.forumotion.com/t71-for-build-howto
However, I do not know this is still valid. I will try myself on new Linux distro...
Quote from Deleted user on December 19, 2024, 6:59 amsudo apt install qt5-qmake qt5-default qttools5-dev-tools sudo apt install libqt5svg5-dev libqt5serialport5-dev qtmultimedia5-devThis installed all what is needed on KDE Neon. Then:
qmake make all -j8Parameter -j8 will force 8 jobs when compile.
That should be all.
qmake
make all -j8
That should be all.
