Forum breadcrumbs - You are here:ForumGeneral: HelpHow can I use the ampmeter?
What does the right pin, 'Right Pin: Output reading as voltage (updates at circuit FPS)' mean in the ampmeter? I don't know how to use it.. plz help me..
Right Pin has a voltage equal to the reading in Amps.
For example if the reading is 1A then you have 1V at right pin. If the reading is 100 mA the you have 100 mV.
