Help with subcircuit/scripted circuit
Quote from average_simulide_enjoyer on February 4, 2025, 7:52 pmI was wondering if there was some way to create a circuit/chip for measuring resistance of a circuit.
Im building some circuits with transistors and stuff and it's annoying to get the equivalent resistance of a specific section, mostly input and output resistances.
I was wondering if it was possible to make a pseudo-ohmmeter.
For the input resistance or a resistance in a part of the circuit, a simple scripted chip that takes in a voltage in 2 pins and the current going tru it in other 2 inputs, or share one of the voltage pins to share. I just don't know how to make a display that shows the value of the resistance by doing V/I
And for output resistance, a scripted circuit that can read the open circuit voltage, then short to ground and measure the current, and do V/I and display it
Anyone knows if this is possible?
Quote from arcachofo on February 5, 2025, 12:43 pmHi.
Attached 2 examples of voltmeters made with subcircuits and script.
I think you can modify for your use case.
If you have any questions feel free to ask.One is made with 7 segment BCD displays and the other one with a Text component:
Quote from average_simulide_enjoyer on February 5, 2025, 11:18 pmVoltmeters are fairly simple indeed. However, for impedance (resistance for DC only), we also need the current.
I know there's no script function to directly read current, but there must be some interesting tactic.
Quote from arcachofo on February 5, 2025, 11:31 pmYou can know the current by reading the voltage drop across a resistor.
Just use a very low resistance.
Quote from average_simulide_enjoyer on February 6, 2025, 11:02 amQuote from arcachofo on February 5, 2025, 11:31 pmYou can know the current by reading the voltage drop across a resistor.
Just use a very low resistance.wouldn't that alter the actual current coming trough the circuit?
i was looking at the ampmeter and i realised it has an output of the current as voltage. i thought i would never use the 3rd pin of voltmeters and ampmeters, but i was wrong lol.
on another issue, is it possible to get a help txt file for my custom components? without putting them in the help folder?
Quote from arcachofo on February 6, 2025, 6:33 pmwouldn't that alter the actual current coming trough the circuit?
Yes, that is why you should use a very low resistance, maybe miliOhm or lower.
But if you go too low you can get some error from floating point calculations.Maybe putting something like this in a subcircuit, the script reads voltage across the resistor, do some calculations and write the value to a Text Component:
You can use that pin, but it updates at "Canvas Refresh" rate, 20 Hz by default.
However in this case it might be ok.
Yes, just add a txt file to your component folder with same name than the component.
For example for mycomponent.sim1 use mycomponent.txt
