display hd44780
Quote from michele on January 29, 2025, 3:39 pmciao a tutti, ho un problema con il display HD44780, credo che sia un bug. lo shift del cursore tramite il comando " Cursor or Display shift" non lavora.
Lo shift del display è ok, mentre lo shift del corsore è ko.
Con altri simulatori il tutto è ok, quindi credo che non sia un problema di codice.
GrazieHi everyone, I have a problem with the HD44780 display, I think it's a bug.
Shifting the cursor using the "Cursor or Display shift" command does not work.The display shift is ok, while the cursor shift is ko. With other simulators everything is ok, so I think it's not a code problem. Thank you
Grazie
Thank you
Quote from arcachofo on January 29, 2025, 6:48 pmHi. Thanks for reporting.
You are right, Cursor Shift is not working at all, so bug confirmed.
It will be solved as soon at possible.
Quote from michele on February 24, 2025, 3:25 pmhello @arcachofo, thanks for upgrade, the problem is half resolved.
the rigth shift is ok, but the left shift don't work.
the left shift command move the cursor at rigth.
Quote from michele on February 25, 2025, 10:17 pm😅 @arcachofo you're right, the shifts are ok.
Excuse me, i made a coding error 🫣🫣
Quote from michele on August 6, 2025, 10:59 amhello @arcachofo, I found that shifting right and shifting left comand work in reverse mode. Can you fix that?
Thank you very much.
Quote from michele on August 8, 2025, 9:57 amhello @arcachofo, yes, the shift works, but in reverse: the left shift command performs a right shift and vice versa.
The code in the real circuit performs the shift in the right direction; in the simulation, it performs it in the opposite direction.
During the simulation, I have to reverse the left and right shift commands.
Quote from michele on August 8, 2025, 2:38 pm@arcachofo, this is my code and related resources.
